Advanced Editing Options
The options in the Edit submenu allow you to manipulate individual geometric entities to create new patterns.
You can also group patterns so that the system processes the individual entities defined within the group as a single pattern, or explode or split patterns into individual geometric entities.
See also -
Blend Patterns Bend Relief Smooth Segments
Trim and Extend Intersect Patterns Convert Options
Pattern Line Join Patterns Part Bending Options
Pattern Grid Parallel Lines / Offset Part Define Options
Pattern Circle Tangent Patterns Process Geometry
Pattern Arc Chamfer Lines Reference Point
Exploding & Splitting Patterns Group Pattern Options
