Material Option Panels
Material files are used to define default material values that are used by your machine driver. Each material file for a machine is unique. You must create a material file for each machine. For most cutting and combination machines, you must also create a material file for each material type used.
In some legacy punch presses, the settings in the material file pertain only to the estimated runtime in your setup sheet. A driver manual that explains each item in the material file usually accompanies the driver. The values for these items are generally found in the programming manual for your machine.
For more information on the use of the various panels listed here, consult your driver documentation.
Material Library
Corners Panel
Open (Loading) Material Files
Punching Microjoints Panel
Saving Material Files
Cutting Microjoints Panel
Printing Material Files
Condition Tables Panel
Exporting Files in XLS or CSV formats
Process Type Panel
    Split Cutouts,
    Perimeter Notch Relief,
    Split Sheet
Lead In and Lead Out Panel
CNC Code Panel
Pierce Location Panel
    Fast Laser Cutting
Processing Options
