What is Fast Laser Cutting?
Using Fast Cut is like choosing to drive
 on a freeway rather than on surface streets. Streets have so many stops
 that
a driver can never attain the speed limit, but on the freeway a driver
 can achieve and maintain the highest speed possible.
Usually a laser head completely cuts out one pattern before moving on to the next. But Fast Cut smoothly continues laser head motion as though cutting out a figure 8. The laser head, moving in continuous half-circles, cuts out the top of the first round (#1); the beam then pauses while looping in a half-circle between patterns around the lower half of the 8 (#2). When the laser head comes to the second round (#3), it powers up again, cuts the top half, loops under #4 and continues in this way until the upper half of all the rounds are cut (#5). Fast Cut then continues around the last pattern to cut out the bottom halves (#5). Entire pattern groups can be cut in this manner, drastically reducing overall laser cutting time.  |
Note: The option is only available for AP100US Premium users. Ask your sales consultant for more information.
Create a Pattern Grid
A good way to begin is by dragging out a grid of similar patterns using options on the Draw / Edit tab. The image here shows that one Round pattern was drawn on a part and then the Round was gridded into a pattern using Pattern Grid on the Draw / Edit menu. After the grid is placed the user may then make adjustments in the Pattern Properties pane. The user may first create a grid of patterns and use Fast Cut directly on the grid, or if need be the grid may be Exploded, because Fast Cut also works with patterns that are ungridded or ungrouped.
See Draw>Draw Patterns and Edit>Edit Patterns for more info. See also Cut Sequence tab>Fast Cut on how to enable this feature from the AP100US interface.
Define Fast Cut
To define a Fast Cut, the user must manually define a group of patterns by selecting the Define Fast Cut option and then dragging out a box to enclose the patterns to be Fast Cut. See the Cut Sequence>Fast Cut options on the Cut Sequence tab.
When this is done the system recognizes the pattern shapes and applies the default Round pattern option set.
The user may then select the specific type of Fast Cut by toggling through the option buttons in the Fast Cut Settings mini-window and choosing a different Round Hole option. The program will then dynamically change the sequencing of the pattern.
Only patterns that have been Fast Cut defined will be cut out using Fast Cut. All remaining patterns will be bypassed, and the program will sequence these "undefined" patterns according to default settings.
Different Pattern Sizes with Same Center
 Point
Pattern groups may contain patterns of different sizes, but if they share
 center-points that are in one line they can be defined and cut by Fast
 Cut.
If
 part sizes differ the program will default to inner-tangent
Fast Cutting regardless of the option selected by user
Fast Cut focuses on smaller patterns that are nearer together. A grid of
 larger patterns that are spaced farther apart may not be definable by
 Fast Cut.
The Fast Cut
 submenu will not display when a Combo machine is loaded.
Fast Cutting does not use lead-ins (except for the first pattern) or piercing.
Fast Cutting functions in both Part and Sheet views.
Amada
 recommends these material specifications for Fast Cutting:
For 2kW & 3kW machines: Mild steel – Up to 1.6 mm. Stainless Steel
 -1.0 mm. Aluminum -1.0 mm.
For 6kW or 9kW Amada FOL AJ or LCG AJ machines materials up to 12 gauge
 can be Fast Cut.
Selecting Fast Cut Options
Options chosen will give results that can differ according to many different variables, such as operator experience and machine characteristics when cutting a certain arrangement of patterns/parts on a sheet. This section is intended to serve as general guidelines.
The user may view instructive Demo Videos for the Fast Cut feature, in addition to other New Enhancements in this release.
		Round Hole Fast Cut Options Sequence 1: Round hole with Arc tangent. Use with Amada's FOL Laser Machine. Sequence 2: Round hole with Line tangent. Use with Amada's FOL Laser Machine. Sequence 3: Arc and Line tangent. Use with Amada's LCG Laser Machine. Use this option in conjunction with Area Fast Cut when ungridded (exploded) Round patterns of different sizes are on a part. Note: The red lines indicate laser head movement between patterns when the laser is powered OFF. The laser head retains the same distance from the part throughout the process. The laser head will loop between patterns wherever the distance between patterns is less (noticeable especially in Sequence 1).
		Double D Fast Cut Options Sequence 1: Line tangent. Use with Amada's FOL Laser Machine. Sequence 2: Arc and Line tangent. Use with Amada's FOL Laser Machine. Sequence 3: Line tangent. Use with Amada's LCG Laser Machine.
		Obround Fast Cut Options Sequence 1: Obround with Line tangent. Use with Amada's FOL Laser Machine. Sequence 2: Obround with Arc tangent. Use with Amada's FOL Laser Machine. Sequence 3: Obround with Line tangent. Use with Amada's LCG Laser Machine.
		SQ/RE Hole Fast Cut Options Sequence 1: Square with Line tangent. Use with Amada's FOL Laser Machine. Sequence 2: Square with Arc tangent. Use with Amada's FOL Laser Machine. With this option Arc Radius and Distance values may be entered to avoid conflicts with adjacent patterns.
 Red line indicates Sequence 3: Square with Line tangent. Use with Amada's LCG Laser Machine.  |
		Rounded Corner Hole Fast Cut Options Sequence 1: Single D. Use with Amada's FOL Laser Machine. Sequence 2: Rounded Corner Hole. Use with Amada's LCG Laser Machine.
		Single D Fast Cut Options Sequence 1: Single D. Use with Amada's FOL Laser Machine. Sequence 2: Rounded Corner Hole. Use with Amada's LCG Laser Machine.
		Use these options to place a [microjoint] tab on cutout corners to prevent loose cutouts from tilting and causing a collision or other stoppage. Enter a size for the tab on a cutout. A default of 0.010 is given, but the user may adjust this as needed. Enter the minimum width of cutouts to be tabbed. If the cutout is smaller than 1.5 (default), there is no need for a tab because a small cutout should drop harmlessly from the table. User may adjust this value as needed.
		Click Advanced Settings to open the window shown here -  |
Values entered here are passed to the C:\AP100US\Parm\FastCutSet.ini file
Skip
 Rectangle Minimum Space
Using Fast Cut when distances between patterns are very close causes the
 head to slow down between rows and also creates a lot of heat on the part
 (for example, when etching bar codes on parts). To counteract these problems,
 the user can enter a value in the Skip
 Rectangle Minimum Space field to enable the “skip” option.
Distances in X/Y between patterns that are equal to or smaller than the value entered will be skipped by the program. When Fast Cut finishes the first pass, it will return again to cut the skipped rows, but in reverse order. This allows a steady laser head movement to be maintained, while allowing rows to cool off after being cut.
Skip Fast Cutting in the Y direction
Max
 Radius for Turning Arc
When Fast Cut turns to the next pattern using a tangent arc, if the turning
 arc is too large laser head movement may exceed the table size. If the
 arc is larger than the value given, the system will use a direct line
 cut to go to the next point.
For example, if a value of 1.5 is entered we can see that the distance between lines on the left is 1.383, smaller than the value entered. This means that Fast Cut will use an arc. But because the distance on the right is larger than 1.5, Fast Cut will turn the arc using straight lines.
OverCut
 Size
The purpose of this option is to make sure that a cutout has been fully
 cut and will easily drop from the sheet. The option will make an oversized
 (longer) cut, based on the value set in the OverCut Size field.
Box Define Max Size
Define the maximum length
 of a Defining box in X and Y. The user must enable the option in the C:\AP100US\Parm
 folder by placing a "1" as indicated.
Note: Based on the Max values entered for Fast Cut boxes, the system will coordinate and even out the size of each box for a neater sheet.
Tolerance
When Fast Cut is cutting a group of patterns, if one line is a little “off” (maybe longer or shorter) it will be ignored by Fast Cut. After the patterns have been cut, the system will then have to send the laser head back to make that one cut. There are two methods to resolve this -
Tolerance
 Adjustment - Use Tolerance Adjustment
If the user checks ON the Use Tolerance Adjustment switch and also enters
 a value in the Tolerance field, if the lines are within the given tolerance,
 the pattern will be adjusted in the X or Y direction to make sure it is
 in the same line along with the other patterns.
Fast Cut straightened out (moved) the
 uneven line and made an even cut
Tolerance
Tolerance allows Fast Cut to adjust the cutting line, to include an uneven
 line in the fast cut as in this image. To enable enter a tolerance value
 in the Tolerance field. The Use Tolerance Adjustment checkbox should be
 switched OFF for this option.
Notice that the uneven line indicated by the red arrow was included in the Fast Cut
Distance Tolerance
If the distance of the trace line for Fast Cut is very large, the head movement may take up too much time when fast cutting. In order to resolve this problem, add a distance tolerance value. If the distance between patterns is greater than the given Distance Tolerance value, then Fast Cut will not be enabled. In the image on the left the system is trying to Fast Cut the entire array of patterns; notice the amount of head movement. The image on the right shows how much head movement was decreased after enabling this option.
Distance
 Tolerance
A large Distance Tolerance value allows Fast Cut to cut an array of patterns
 as one cut, but the head movement may take up too much time. Entering
 a smaller value allows Fast Cut to divide the pattern array into several
 manageable sections, thereby controlling head movement.
Distance
 Tolerance Switch
To enable Distance Tolerance, check ON the Use Distance Tolerance checkbox.
Skip
 Hatch Minimum Space
This option allows Hatch Etching and Fast Cut properties to be used together.
If the value in Skip Hatch Min Space is larger than the Hatch Interval
 value set in Hatch Etching, Fast Cut will
 skip the next hatch etch line and cut the line after that one instead.
Since the distance between patterns when using the Hatch Etching option is also very close, the skip method can make the cutting speed faster and is good for heat dissipation. If the value in “Skip Hatch Min Space” is larger than the Hatch Interval value set in Hatch Settings, Fast Cut will skip the next hatch line and cut the line after that one instead (similar to Skip Rectangle Min Space above).
One
 Tab Switch
If this option is checked ON, Fast Cut will leave only one tab in a cutout.
 With the option checked OFF, the program may add several tabs in one cutout.
 This option works in conjunction with the Tab Size for Cutout and Min
 Width of Cutout value fields shown above.
Tolerance
 for Circle Define
When defining a pattern circle, Fast Cut will attempt to place patterns
 in a group. To do this, a circle center point or points between patterns
 must be identified by the program. Entering a tolerance value means that
 Fast Cut will assign a common center point to multiple center points that
 are within a certain distance from each other (within the tolerance value).
 Center points outside of that distance will be recognized by the system
 as separate center points.
Note: Using a large tolerance value allows the program to regard multiple center points as one center point. In such cases Fast Cut can only guarantee the accuracy of the cut on the first pattern - cuts on following patterns may become increasingly inaccurate (off center).
Angle
 Tolerance
Fast Cut will calculate the spacing between patterns. If one pattern is
 off center, Fast Cutting will be interrupted. For example, when trying
 to define a circle line, Fast Cut will notice that one circle is not directly
 in line with the others. To counter this the user may then enter an Angle
 Tolerance value, enabling Fast Cut to define all the circles as one line.
