Draw Patterns
The Pattern submenu on the Draw / Edit tab, consists of the following options:
Line Shape Library Text Options
Multiple Lines Rectangle Hole Ellipse
Rectangle Lines Center Rectangle Hole Notch Library
Rounded Corner Lines Rounded Corner Hole Radius Slot
Round Hole
Triangle Hole
Place Tool Hits
Arc Single D Add Flange
Arc 3 Points Double D Rotate Part
Obround Point
AP100US has two types of patterns - standard and polygon. Standard patterns consist of single entities, whereas polygon patterns consist of multiple entities.
These Pattern Properties windows appear for Standard and Polygon patterns
Note: To precisely position patterns try the Coordinates feature in the Draw menu.
