Part Stacker
Module
The Part Stacker
Module allows the user to clearly view the results of a part removal operation
on the stacking table, and also to re-arrange
the final stacking position of each part.
To
open the Part Stacker Module, from the Modules interface
in the AP100US program click the Edit
Stacking button.
Note:
If the Stacker module doesn't launch, it may be because this button
has been disabled in Preferences>Display
options. |
If the parts
have been unloaded to the part stacking table in the AP100US Modules work
area, when the Part Stacker module opens the parts will appear in that
placement as in the image below.
A sheet or
job file may also be opened by in the Part Stacker by clicking File>Open
and then selecting a file.
New
Click to
open an SY2 file, Sheet file, Job file or Schedule file in the Stacking
module. If there is a file currently on the stacking table, the program
will ask to clear the data base before proceeding. Click Yes
to proceed
or No to
cancel the operation. If Yes
is selected,
the Open File window will display; browse to the
necessary folder.
Open
To
load parts for stacking from existing files, click Open to display
the Open File window (shown above).
Save
Select
Save
to save
any changes made to the sheet on the stacking table.
Print / Printer Setup
Choose
Print
to print
out a copy of the current sheet in hard copy. If your system does not
connect, search for and configure settings for the printer by selecting
Printer
Setup.
Exit to CADCAM
This
option will close out the Part Stacker module and the AP100US
program will return to view.
TK
or PSR Settings
This
option allows the user to view and edit PSR or TK settings in a simplified
window.
See
PSR Unloader Settings or TK
Unloader Settings for complete info.
Auto
Stack Layout Settings
These
settings enable the user to enter Offset
and
Spacing
values,
selecting a Preferred Corner,
as well
as Location X/Y and Width/Height
settings
for Cardboard insertion.
Choices
made here will not be applied to a stacking table arrangement currently
on the stacking table; the user must Reset
and then
Auto
stack the
table again for changes to take effect.
Note:
When stacking in the CAM program the system will use settings from the
Auto Stacking Layout Settings dialog in the Stacking Module.
Changes
made here become the default until changed
The
Move,
Delete,
Rotate
and
Select
options
function here as they do in the Sheet
menu, but instead of using a cursor crosshair as in AP100US,
an arrow cursor is used in the Stacking Module.
Reset
Clicking
this button resets a stacking placement that exists on the default stacking
table in the work area. Parts will be
sent to the Part List and may be placed again on the stacking table.
Reset
All
Clicking
this button resets all stacking placements that exist on all stacking
table layouts that have been created.
Parts will be sent back to the Part List and may be placed again on the
stacking table(s).
Auto
Select
this option to allow the program to automatically place parts from the
Part List on the default stacking table, which will be carried out according
to default and user-entered settings.
Note:
When auto-stacking parts on a pallet/table, if there is more than one
pallet on a table and there are too many parts to fit on the first pallet,
they may be pushed to the next pallet on the same table.
Auto
All
Select
Part List on all stacking table layouts that are in use in a given table
layout, which will be carried out according to default and user-entered
settings.
Move
When
Move
is clicked
and a part or part kit on the stacking table is then selected, it becomes
attached to the cursor (snapping to the nearest corner) and can be relocated
by dragging the part, left-clicking again to place.
The user may
also manually enter values in the X
and Y fields that appear in the
X / Y location flyout attached to the cursor, or the Location
fields found in the part Properties
panel. After typing in values, hit <Tab>
to enter the value and jump to the next field, or hit <Enter>
to confirm the entry, complete the operation and release the part.
When a part is
selected the X field in the Location flyout
is active; use <Tab> to jump to the Y field and back
Location &
angle can also be selected by
clicking the arrows in an active cell
Note:
The values given in the Properties
panel show
absolute values based on the natural base point (lower-left corner) of
the part or part kit. However, the values given in the flyout that is
attached to the cursor show incremental values, based on the corner that
the cursor is attached to. For this reason, the Location values for a
part in the Properties panel and in the location flyout may differ.
When the
Move icon has been selected, the Move Parts Number option on the menu
bar becomes active (as shown in the image below). The user may then select
the quantity of parts that will be placed in separate stacks, which can
then be dragged out to different locations on the stacking table.
For example,
if there are ten similar parts (and the Max
Storage Height value
in TK Settings permits such a stack) the program
will by default stack these ten parts together in one stack. However,
if the user prefers to have five stacks of two parts each, he must enter
a value of "2" by clicking the up button. The user may then
click the original stack and drag four other stacks (each consisting of
two parts) one by one to a new location on the table.
Cardboard / Auto Cardboard
For
info on these options please see Cardboard
Insertion.
Stack
Parts
The Stack
Parts checkbox is enabled by default as this is the most likely choice.
This allows the program to stack similar parts at the same angle in one
stack. The height of the stack is controlled by the user-entered value
set in the TK or PR Setting windows. (This
value is passed on from the PSR Settings in
the AP100US program
and saved with the machine file; it is editable in the Stacking Module.)
Uncheck
this box to NOT allow similar parts to stack one on top of the other.
Display
Stack Quantity
Check
this box to allow each part stack to show a number, indicating quantity
of parts in the stack. The above image shows part stacks that have two
parts per stack.
Note: When the cursor hovers over a part stack, the Stack Height will display
in a small flyout attached to the cursor.
Display Arms
Enable
this option to show the part remover arms when a part is selected.
The
dashed red line on stacking tables indicates the extent or "reach"
of the part remover arm as shown in this image -
Floor Cart
2 is completely within range of the PSR; however, Floor Cart 1 is problematic.
Parts shown in red will not or may not be stacked correctly.
To
show the dashed red line on stacking tables, the Show Arm Dead Zone option
must be enabled. For more info see PSR Unloader Settings or TK
Unloader Settings.
By
default, when picking up parts the two suction cup arms are close together
and the suction cups make contact at or near the center of the part as
in this image -
Active suction cups are shown in red
Customizing
the assignment and placement of suction cups is possible in AP100US work
area. See Modules>Edit
Arm and PSR Unloader Settings or TK
Parts are
shown in red only in documentation; in the Stacker module actual out-of-range
parts are NOT colored red.
Display
of the arms depends on the driver/machine in use.
Stack
Table menu
Click
for info on how to create, edit and use Stacking
Tables.
Pallets
menu
Click
for info on how to create, edit and use Pallets
and Pallet Layouts.
Cardboard
menu
Click
for info on how to create, edit and use Cardboard
Insertion.
The
View
menu offers
standard choices. When clicked, Zoom
All will
fill the work area with the stacking table and parts.
Click
Zoom
In &
Out
repeatedly
to zoom the view. The view may also be zoomed by scrolling the center
mouse button while the cursor is in the work area.
Click
Pan, move the
cursor into the work area and drag the view to pan. The view may also
be panned by holding down the center mouse button and dragging the view.
The
Undo and Redo options
are under the General menu. See Move
above on this page for info about Move
Parts Number.
Click
the Question icon to open the general AP100US Help file.
Part Stacker documentation is found under the Modules menu.
Part List
The
Part List shown here lists the sheet files that have been loaded
into the Stacking module, as well as the individual parts in each
of those sheets. When the parts are unloaded onto the stacking
table (either by Auto or manually), the part names will disappear
from this list.
Select a part to see
a thumbnail in the Part Display. Right-click a part list and click
Remove to
remove it from this list.
Right-click
on a sheet name to open the flyout menu.
Select
Auto
to
auto-unload this sheet to the stacking table in the work area.
Clicking
View
(placing
a checkmark) hides the parts in the work area from view.
Remove
Sheet deletes
the sheet from the Part List.
If
a job file has been opened, click Remove
Job to
delete it from the list.
If
a schedule file from Sheet Wizard that contains two or more sheets
Relation to
remove that sheet from the schedule file, allowing it to be edited
separately. |
The user may also left-click
a part (or part kit) in the Part List
and drag it onto the stacking table, left-clicking again to place it.
Coordinate values can be directly entered into the X
and Y flyout fields that are attached
to the cursor. After typing in values,
hit <Tab> to enter the value
to confirm, complete the operation and release the cursor.
Note:
When entering values here if the user does not hit <Enter>,
the cursor will remain attached to the part, prohibiting any further action.
The
padlocks in the image below indicate that the user has typed in values
in the first and second fields and has hit <Tab>
after
each entry. When <Tab> is
hit after an entry 1) the part jumps to the new location, 2) the value
is "Locked" in that field and 3) the
cursor will jump to the next available field. At this point the cursor
will still remain attached to the part, preventing further user input.
The user must then hit <Enter>
to release the part. When
typing in values in either the flyout (shown here) or in the Properties
panel,
hitting <Enter> will complete the action.
Padlocks indicate that
the field has been locked
When a part is selected a
Properties panel for that part
opens on the right side of the work area, showing absolute values for
the part.
Enter Location and Angle values and after typing in values hit <Tab> to enter the value and jump
to
complete the operation. All other fields in the Properties panel are read-only.
over a part stack,
the Stack Height will display in a flyout
attached to the
cursor
When
the Graphic View tab is clicked,
a graphic view of the parts with read-only info displays for parts in
a selected sheet.
Output
Panel
The
Output panel at the bottom of
the work area gives basic instructions and results for the user.
It also has an Inch/Metric toggle
that applies to all values in the program.
