Add Microjoint Tool Sequence
The Add Microjoint Tool Sequence option allows the order of the bridge microjoint tool hits in the sequence to be specified. The option is only available if you have specified the use of bridge tools to create the microjoints.  See Place Microjoint, Edit Microjoint and Microjoint Window in Sequence Features for more info.
Before you attempt to use this option, open the Turret window and make sure that a tool has been designated as a microjoint tool. See Punching Microjoints Panel for info on how to designate a tool as a microjoint tool.
To specify the order of the bridge microjoint tool hits in the sequence, switch to Sheet view. If necessary, use the Zoom options on the View menu to magnify the view. Select Add Microjoint Tool Sequence and the pointer bounces between those microjoints that have bridge tool assignments. Move the pointer onto the microjoint of choice and click. The punching direction arrows appear on the path and the bridge microjoint appears in the Pattern Sequenced color (Color Parameters/Preferences window).
Note: This is a manual method for controlling the sequence. The user may also automatically control the tooling sequence by sequence priority options. (See Tool Sequence Priority window for more info.)
Remove Microjoint Tool Sequence
The Remove Microjoint Tool Sequence option is only available if you have specified the use of bridge tools to create the microjoints. You would use this command to remove any bridge microjoint tool hits from the sequence. The option will remain active until you select another command. See Edit Microjoint, Microjoint Window and Delete Microjoint in Sequence Features for more info.
To remove a bridge microjoint tool hit from the sequence, switch to Sheet view. If necessary, use the Zoom options on the View menu to magnify the view. Select Remove Microjoint Tool Sequence and the pointer bounces between those microjoint tool hits that have been added to the sequence. Move the pointer onto the microjoint to be removed and click. The punching direction arrows on the path and the tool hit will revert to the Tool Hit/Cutting Direction color (Color Parameters/Preferences window).
Note: This is a manual method for controlling the sequence. The user may also automatically control the tooling sequence by sequence priority options.(See Tool Sequence Priority window for more info.)
