Machine Information Panels
When you have loaded a machine (*.mac) file, you can then access the Machine Setting window to modify the machine file. Select Machine Info from the Machine menu.
The options in the Machine Setting window are dependent on the currently loaded machine file. For example, if a cutting system is loaded, then only those options specific to cutting machines are available. The name of the machine file appears in the title bar of the Machine Setting window.
Description Panel
Sheet Layout Info
Place Support Pins
Work Chute
Sequence Information
Run Time Estimate
Reposition Information
