		Click the Add button to add tools to the PDC. The PDC Storage window will update and display the Tool List. To add a tool to the PDC, click and hold the tool name in the Tool List on the right and drag it to an empty station in the PDC Storage list.
		Use the scroll bar to locate the desired tool in the Tool List window. When you select a tool name, the die clearance information appears below the list. You must select the correct clearance value below Die Clearances before you can add the tool to the PDC station. Notes: Only the total number of die clearances display for the tool. If the tool only has two die clearances, then only those two values appear. These instructions also apply to the ATC Storage when an Amada Acies machine is in use.  |
Output a Tapping Tool to SDDJ
Note: This option is specific to the ATC Storage unit.
A Tapping Tool can be output to the SDDJ server. When a tapping tool is selected in the Punching Conditions dialog (shown here outlined in red), it can be output to the Process Information panel of the SDDJ server as outlined in red in the next image.
Input values are from 1 to 7, which indicate different tool types.
For more info see Tapping Tool Info.
This option only takes effect for Round and Special tools, typically used for tapping.
After being saved to SDDJ, the tool will display in the Shape column on the Used Tooling tab.
Note: This only applies to ATC-type machines that are using the SDDJ server.
For general Punch Condition rules and info, see Punching Conditions Dialog and Punch Condition Options.
