View Cut Sequence
To see the cutting sequence, select View Sequence. The sequence displays as the work area redraws.
Use the View Speed Slider in the lower right corner of the AP100US interface to select a viewing speed.
The user may also use key commands to control viewing speed.
1-9 = speed, 0 = single step, <Enter> = Skip, <Esc> = Cancel.
Controlling the viewing speed can also be done in Preferences>Display Options.
To allow the program to show the part unloading process as soon as the sheet is sequenced while in the Cut Sequence menu, make sure that the Auto Unloader checkbox in Machine Setting>Sequence Info is checked ON.
