Machine File (including Loading & Saving)
A machine file contains the physical parameters of a machine. The information includes the machine type (punching, cutting, combination, PDC), the driver used, whether there are work chutes, station data, etc. A machine file has the file name extension of *.mac, and is stored in the Turrets directory.
Normally, machine files for your existing machines are supplied when you purchase the software. However, you may need to modify the machine file. It is extremely important to input the correct information to generate accurate NC code. The documentation supplied with your machine lists the information necessary to create a machine file. See Understanding Machine Drivers for more info. Saving a Machine File
Loading a Machine File
Machine files are stored in the Turrets directory. To open a machine file, select Open… from the File menu. Click the Files of type: arrow and select Machine (*.mac) from the drop-down list. The Open File dialog box updates, displaying the names of the machine files. Select the desired machine file and click Open, and then click Close to continue.
Notes: If there are material files associated with the machine file, the Select Material File window appears. If you want to load a specific material file, click its name in the list, and then click Load. If you do not want load a material file, click Cancel. If a material file is not listed, click Browse… and navigate through the Open dialog box to select a material file. (See Material Files.)
If only one material file is associated with the machine, the system automatically loads it. The Select Material File will not appear, nor does the system request that you create a material file. If there is no material file associated with the machine driver, the system prompts you to create one. (See Material Files.)
If you have created or modified a machine file, you must save it. To save a machine file, select Save As from the File menu. Click the Save as type: arrow and select Machines (*.mac) from the drop-down list.
Type the new name for your machine file in the File name: text box, or select the name of the machine file that you want to overwrite in the list. Click the Save button to save your file. Click the Close button to exit.
