MENU
Home Page
Company
Products
Software Products
AMADA School
AMADA IIOT
Online Order: Parts & Tooling
Log-in & New Users Registration
Contact Us
Products
AMADA School
AMADA IIOT
Contact Us
AMADA MACHINERY AMERICA
AMADA WELD TECH
AMADA PRESS SYSTEM AMERICA, INC.
AMADA WELD TECH
< Back to Software
bottom
Punch/Cut
Bending
3D Solid
Factory Management
Automation
Quality Control
Sales
Bending: |
Dr.ABE_Bend
Dr.ABE_Astro
Dr.ABE_Bend: |
Overview
Value Proposition
Features
Specifications
Dr.ABE_Bend Features
Dr.ABE_Bend has expanded support for the latest in press brake technologies. Your shop can integrate Amada FBD, HDS, and HFP press brakes, in addition to other current press break machines.
Dr.ABE_Bend has built-in notifications that let you know when there is a fault in the NC code or processing of parts. You can rely on system checks that the application runs in real time, to alert you to system errors and help you pinpoint problems.
Dr.ABE_Bend provides a clear, easy system for automatically assigning Tool Conditions, with user-determined Tool Priorities. Rely on Dr.ABE to suggest tool auto-assignments for completing your parts, based on how frequently you use tools, materials, and thicknesses, while still giving you total control of Tool Priority. The “V-width information” set are also automatically retrieved from the unfold drawing.
Multiple parts batch tool setup (optional feature) Using one setup of tool stages, make machine utilization and run-time increased, due to lack of setup times.
Dr.ABE_Bend handles Automated generation of multiple machine processes for you. Now your shop can repeatedly run the same job or several different jobs across more than one machine, from one pc control. Amada’s total bending solution walks the user through the process of setting up scalable, helpful programming for your machines.
Experience dramatic reduction in "setup and runtime." Dr.ABE's bend engine system has been redesigned to yield the fastest performance yet! Reduced work time benefits your shop, your clients, and your ability to take on each and every job with precision and excellence.
When coupled with our advanced VPSS solutions, faster bend data processing can be stepped up by as much as 73%!
Dr.ABE_Bend is fully backwards compatible. The advanced bending solution still supports legacy Bend/CAM version files and functions. This is accomplished by integrating Bend/CAM v4 for manual operations.
More Control Types For legacy support, Dr.ABE is fully compatible with RG machines with NC9EX controllers and not just newer, PC-controlled systems. The result is your shop is ensured that the user will be able to run parts from the past, and still gear up for the future.
top
