RMP 3015N TK
Load/Unload and Parts Removal
Compatible Models: EML, ACIES, LC C1 AJ, EMK MII, EM ZRT
View Brochure
RMP 3015N TK
  • home
  • RMP 3015N TK
raw material, part removal, and skeleton extraction—all in a rear-side, space-saving design
The RMP 3015N TK from AMADA is a high-efficiency automation cell that handles raw material, part removal, and skeleton extraction—all in a rear-side, space-saving design. With its vacuum-based take-out unit and clamp system, it precisely separates finished parts from micro-jointed scrap and stacks them efficiently. Whether working with a turret punch press or laser/punch combination machine, RMP 3015N TK helps you boost throughput, reduce manual labor, and maintain front-side flexibility for your shop floor.
  • Full automation in a compact footprint includes loading, part removal, and skeleton handling.
  • Rear-takeout design leaves the front of the machine free for JIT work, setup, or manual feeding.
  • Supports turret punch presses and combination machines.
  • Vacuum pads, using two independent arms, pick up and stack parts, clamps remove skeleton or micro-jointed sheets..
  • Built with a rigid, tubular welded frame for long-term reliability.
RMP 3015N TK
  • Supports 3,000 x 1,525 mm max. sheet, 915 mm x 305 mm (36" x 12") with thickness Range of 0.5 – 6.0 mm.
  • Includes three 3-ton pallets (one for raw material, one for finished product, one for skeleton) in the standard configuration.
  • Max. part size: 2,800 x 1,450 mm, min. part size: 100 x 50 mm (depending on machine). Max. part weight: up to 120 kg when using two TK arms.
System Max Sheet Size Min Sheet Size Sheet Thickness Pallets (Material/ Product /Skeleton) Max Part Size (TK Pickup) Min Part Size (TK) Max Part Weight (2 Arms) Stacking Capacity
RMP 3015N TK ~3,000 x 1,525 mm 915 mm x 305 mm (36" x 12") 0.5 – 6.0 mm (based on core machine specifications) 1/1/1 (2-ton each) 2,800 mm x 1,450 mm (110" x 57") ~100 x 50 mm (machine dependent) 120 kg 260 mm (10.25") stack height
