RMP 3015N
Rear Access Load/Unload System
Compatible Models: EML, ACIES, LC C1 AJ, EMK MII, EM ZRT
View Brochure
RMP 3015N
  • home
  • RMP 3015N
dependable, highcapacity rear-side automation—handling
The RMP 3015N from AMADA delivers dependable, highcapacity rear-side automation—handling large 5' x 10' sheets with a durable, two-pallet system that automates both loading and unloading. Its compact, rigid design integrates cleanly into your shop while preserving the machine’s front for manual or JIT access. For shops looking to boost throughput without a full FMS, the RMP 3015N offers a smart, cost-effective automation upgrade.
  • Supports large sheets up to ~1.5 m x 3.0 m (5' x 10') min. 914 mm x 305 mm (36" x 12").
  • Economical automated loading/unloading with a single load pallet and a single unload pallet.
  • Includes two 2-ton pallets (one for raw material, one for parts/skeleton).
  • act footprint with rear access allows for front manual loading, prototyping, and JIT work.
RMP 3015N
  • Rigid, tubular welded frame provides durability and stability while remaining flexible for integration.
  • Up to 2,000 kg (4,400 lbs.) stacking capacity.
  • Supports microjointed sheets, making it well-suited for parts that remain connected until unloading.
  • Supports turret punch presses and combination machines.
System Max Sheet Size Min Sheet Size Sheet Thickness Pallets (Material/ Product /Skeleton) Stacking Capacity
RMP 3015N ~3,000 x 1,525 mm 510 mm x 205 mm (20" x 8") 0.5 – 6.0 mm 1/1/1 (3-ton each) 260 mm (10.25") stack height
