MP 2512N
Front Access Load/Unload System
Compatible Models: EML, ACIES, LC C1 AJ, EMK MII, EM ZRT
View Brochure
MP 2512N
  • home
  • MP 2512N
delivers dependable, highcapacity rear-side automation—handling
The MP 2512N from AMADA brings reliable, front-side automated loading and unloading to turret punch presses —combining a 4' x 8' sheet capacity, robust vacuum-driven handling, and a cycle time of ~28 seconds. It’s a smart automation choice when you want to raise throughput without investing in a full FMS system. Ideal for AE NT turret presses, the MP 2512N increases uptime and reduces labor, all while maintaining a compact footprint.
  • Cost-effective system provides automated material handling for turret presses with minimal capital outlay.
  • Compact footprint fits well on tight shop floors; front-side operation keeps rear space available for other uses.
  • Supports standard 4' x 8' equivalent (1.2 m x 2.5 m) sheets with thickness from 0.5 mm to 6 mm.
  • Automates sheet loading and unloading, allowing the punching process to run with less manual intervention and higher consistency.
  • 28 second load/unload cycle time boosts productivity.
  • Maximum pallet load is up to 3,000 kg (6,610 lbs.) per pallet.
MP 2512N
System Max Sheet Size Sheet Thickness Load/Unload Cycle Max Pallet Load Operation Side
MP 2512N ~1.2 m x 2.5 m (4' x 8') ~0.8 mm – 6 mm ~28 seconds ~3,000 kg Front-side load/unload
