Laser Automation
  • Laser Automation
Available Laser Automation Systems
View More Laser
AMS CLT
AMS 3015 CL & AMS 4020 CL
Modular Automation Solution
view more
The AMS 3015 LL (Linear Loader) is designed for shops requiring a narrower footprint. If your ability to add automation to your laser is limited due to walls, aisle ways, or other equipment, the AMS-LL can be a solution by keeping the system roughly the same width as the laser itself. Like all of the AMS systems, the AMS LL is designed and built in the USA and utilizes many of the same components as the other configurations. The simple and efficient design of the AMS LL can greatly increase the overall productivity of your laser without the need for more floor space.
AMS 3015 LL
AMS 3015 LL
Linear Material Loader
View More Laser
TK 3015L & PSR 3015
TK 3015L & PSR 3015
Part Sorting Robots
view more
Designed to accompany the ENSIS 3015 RI, the ASFH 3015G compact load/unload system allows for sheet material and product storage while the STRI 3015 provides the mechanics for cutting tube. This provides a versatile system for shops looking for both blanking and tube cutting in one system.
ASFH 3015G + STRI 3015
Compact Load/Unload System
The AS 6225 load unload automation is designed for customers looking to optimize production on a large scale. With the ENSIS 6225 AJ working area of 6.2 meter x 2.5 meter (8’ x 20’), this accompanying automation allows storage and prep for multiple sheets to maximize processing time. The system is available with a second station for immediate product removal and also part marking ink jet printer (IJP).
AS 6225
AS 6225
Load/Unload Material Automation
AMADA offers a variety of material warehousing systems. AMADA’s MARS is one of the storage systems that can help organize your manufacturing process from raw material to finished parts. These systems create a centralized location that acts as a “hub” for material and part flow from one process to the next. With the ability to connect to multiple blanking and bending machines at one time, systems like our MARS can feed material to a laser or punch and then return stacked parts back into the system where they can be retrieved later. Material warehousing systems are designed for larger scale storage, with the capability to have more shelves than a standard tower. In most cases, these systems will utilize hundreds of shelves, taking your material and parts storage vertical, saving valuable floor space. Since process flow now goes through this centralized hub, part and process management has never been easier to control.
MARS Storage System
CS/MARS
Material Storage System
