HG 2204 ATC
Press Brake w/ Automatic Tool Changer(ATC)
HG 1303 Rm Series
  • bending automation
  • hg atc series
complex tool layout in three minutes!
AMADA’s HG servo/hydraulic press brake and Automatic Tool Changer (ATC) provide the optimal bending solution for high-mix, low-volume production. The HG ATC Series is an advanced system that achieves precise and economical bending results even in lot sizes of less than ten. The ATC performs tool changes quickly and precisely — eliminating costly delays associated with manual tool changes. As a result, you can can triple or quadruple your number of bending setups per day. The ATC is equipped with 18 magazines for dies and 15 for punches — providing the flexibility to accommodate rush jobs seamlessly. Now, complex tool layouts can be precisely loaded in three minutes or less.
AMADA engineered the HG ATC as an ideal solution for variable lot sizes and complex tool layouts. The Automatic Tool Changer (ATC) can load the most complex tool layout within three minutes and allows operators of varied experience levels to efficiently utilize this bending system.
Quick tool setups achieved by the ATC gives users the ability to introduce rush jobs seamlessly and triple or quadruple the amount of setups performed each day (based on eight setups per day).
Additional Features
  • Ideal solution for variable lot sizes and complex tool layouts
  • Increase the number of tool setups performed each day
  • Reduce operator experience requirements
  • ATC stores 86' (26.4m) of tooling
  • New AMNC 3i control
  • Integrated bend sensor
  • Low energy consumption
HG 2204 ATC with Sheet Followers
