The FLW ENSISe takes laser welding to a higher level of precision and productivity. AMADA's Fiber laser technology provides Process Range Expansion (PRE) by ensuring precise, high-speed results even when processing reflective materials such as brass and copper. The FLW ENSISe is equipped with a patented rotating lens. With this unique feature, the laser beam is no longer aligned with a specific point along the target path — instead it circles within a small area as it is welding. A rotating lens makes it possible to bridge larger and uneven gap sizes while producing a clean, even weld. The heat input into the material is also optimized and results in precisely defined weld edges with virtually no unnecessary deposits of material.
