ENSIS AJe Series
3kW, 6kW, 9kW, 12kW,15kW Fiber Laser
view 3kW Brochure view 6kW, 9kW, 12kW, 15kW Brochure View Specifications
ENSIS Series
  • ENSIS AJe Series
6kW, 9kW, 12kW & 15kW ENSIS Video
3kW ENSIS Video
Processes thick plate efficiently
AMADA's 3kW, 6kW, 9kW, 12kW ans 15kW ENSIS fiber laser technology utilizes a highly innovative resonator to automatically and precisely adjust the diameter of the laser beam. This unique feature enables continuous processing of thin-to-thick materials by a single machine with no lens change or additional setup required.
The ENSIS AJe Series uses AMADA's proprietary fiber laser technology to process both thin and thick materials without a cutting lens change or manual setup. The 3kW, 6kW, 9kW, 12kW, and 15kW fiber engines incorporate AMADA's ENSIS Technology that optimizes the laser mode and Beam Parameter Product (BPP) based on the material thickness being processed. The ENSIS Series achieves high-speed cutting in thin material, a key capability of fiber technology, and the ability to process thick plate efficiently.
ENSIS AJe Series Fiber Laser Standard Features:
  • ENSIS technology allows for continuous variable beam control across
    every thickness of material with no setup
  • 1.4g acceleration over the entire work area
  • Automation-ready
  • Energy efficient
ENSIS Series
