  • Synergy in Action Through Diverse Technologies
EGB 1303 ARs
Electric Automated Bending System
EGB 1303 ARse
  • Bending Automation
  • egb 1303 ARs
fully-integrated Electric robotic bending system
The EGB 1303 ARs is a fully-integrated robotic bending system with a 6-axis bending robot with a traveling axis, automatic gripper changer, and automatic tool changer (ATC) with patented AMADA tooling. Each stage of the bending process, including tool loading, gripper exchange, and robotic bending are all performed at fast speeds to maintain high levels of unmanned machine productivity. The ATC is equipped with four tool manipulators that quickly and precisely position punches and dies along the length of the press brake to eliminate costly delays associated with manual tool changes.
Versatile Bending Robot
To maximize bending flexibility, the EGB ARs is equipped with a 6-axis robot with a traveling axis. Mounted on a rail in front of the EGB ATC press brake, this fully-integrated robot can traverse along the length of the press brake to facilitate multi-stage bending. The enhanced motion capabilities allow this robot to easily perform acute and obtuse bends. Also, the newly developed robot controller improves cycle times and has a reduced footprint to make the machine more compact.
In adherence to the primary section of AMADA's Basic Policy on Sustainability, we are committed to treating people and the global environment with respect. We achieve this goal by reducing CO2 emis­sions, promoting the reduction and reuse of waste, and protecting the global environment, including biodiversity in all processes. We also provide environmentally-friendly products and services through our business activities. https://www.amada.co.jp/en/sustainability
Intelligent AMNC 4ie control
An intelligent AMNC 4ie control allows voice commands to request, change, and verify bend information while the operator is on the move­all as an automatic foot pedal slides to the next bending position to ensure continuous operation.
AMADA's Patented Automtic Tool Changer(ATC)
By integrating a bending robot with the precision of AMADA's EGB ATCe press brake and patented Automatic Tool Changer (ATC), fabricators can automatically bend a variety of parts with maximum accuracy.
AMADA's ATC ensures that tools are loaded quickly and precisely. Four tool manipulators quickly load tooling from 18 punch stockers and 25 die stockers. Each stocker can hold 800mm of tooling. The ATC was engineered to eliminate costly delays associated with manual tool changes.
AMTS Tooling
AMADA’s Modular Tooling System or AMTS is designed to account for the motion during loading and unloading and accurate punch tip alignment. The design of AMTS tooling is an important factor as to why the ATC loads the most complex tool setups in minutes and decrease setup times for longer parts.
Automatic Gripper Changer
The Automatic Gripper Changer will exchange the gripper according to the workpiece to ensure efficient and stable processing. This machine is equipped with various types of grippers to accommodate a wide variety of parts shapes and sizes.
Two Backgauge System w/ Side gauge
A two backgauge system with a side gauge ensures stable positioning of asymmetrical workpieces and simplifies positioning. The side gauge corrects lateral misalignments and stabilizes lateral positioning.
BI-S II Angle Sensor
To further boost productivity, Bi-S II automatically measeure and corrects angles up to 85% faster than Bi-S Technology.
Features
  • 130-ton capacity servo/electric drive system
  • AMNC 4ie Control with vertical multi-touch display
  • ATC stores 112.8' of patented AMADA tooling and is equipped with four tool loaders
  • Multi-axis robot performs consistent unmanned bending operations
  • Two backgauge system w/ side gauge ensures high-precision bending operations
  • Offline programming software generates all articulation code for the robot and press brake
  • Bi-S II angle sensor ensures consistent bend angles
  • 9 gripper station allows robot to move seamlessly from small parts to larger panels
EGBARse Part Loading EGBARse Part Loading
  • Notice and Takedown Policy
  • Privacy Policy
