ASR 3015 PR
“Twin Tower” Automated Load/Unload and Parts Sorting
Compatible Models: EML, ACIES
View Brochure
ASR 3015 PR
*Shown without safety fence
  • home
  • ASR 3015 PR
fully integrated automation solution for punch laser combination cells
The ASR 3015 PR from AMADA is a game-changer for punch laser combination cells, delivering a fully integrated automation solution that handles raw sheet storage, loading, unloading, part sorting, and scrap management—all in one compact system. This design not only saves floor space, but it also boosts productivity by up to 35% when paired with an EML AJ. By enabling parallel loading and unloading in separate safety zones and offering front access for quick manual jobs, you get a flexible, efficient, and highly automated workflow that scales with your production demands.
  • Integrates storage, loading, unloading, sorting, and scrap handling in one system.
  • Compact footprint makes it more space-efficient than separate loading/unloading + sorting systems.
  • Increased productivity of up to 35% is possible when paired with AMADA’s EML AJ.
  • Front access to the machine facilitates quick manual loading for rush jobs or prototyping.
  • Standard setup includes multiple pallets—e.g., 3 pallets for raw material, 2 for finished parts, and 2 for sheet skeletons.
  • Supports sheets up to 3,050 x 1,525 mm and thicknesses from 0.8 mm to 6 mm.li>
  • Part Removal (PR) uses vacuum suction and/or clamps to pick parts.
  • Max. part size is 2500 x 1445 mm, min. is 100 x 50 mm.
  • Sheet handling and part-removal units operate simultaneously in separate safety zones without impacting punch/laser cycle times.
ASR 3015 PR
Specification Sheet Thickness Max Sheet Size Part Size (Vacuum) Part Size (Clamps) Max Part Weight (2 arms) Stacking Heights Number of Pallets System Height
ASR 3015 PR 0.8 – 6 mm ~3050 x 1525 mm Up to ~2500 x 1445 mm Up to ~3050 x 1525 mm 80 kg (using both arms) Material: ~80 mm; Product: ~220 mm; Skeleton: ~220 mm 20 total (10 material, 5 product, 5 skeleton) ~5200 mm
