After a sheet has been sequenced click View Sequence to view the sequence at a controlled speed. Adjust viewing speed by pressing a number key, or use the View Speed Slider in the lower right corner of the AP100US interface to select a viewing speed.
Notes: 1 - 9 = speed, 0 = single step, <Enter> = Skip, <Esc> = Cancel.
To allow the program to show the part unloading process as soon as the sheet is sequenced while in the Punch Sequence menu, make sure that the Auto Unloader checkbox in Machine Setting>Sequence Info is checked ON.
