PDC / ATC Machine Setup
To setup the machine file for your PDC or ATC machine, select Machine Info from the Machine menu. PDC or ATC will appear depending on the machine loaded at the time.
The Machine Setting window contains the same information for PDC/ATC machines as it does for other punching machines. However, the Num PDC (or ATC) Storage field is enabled within the Settings section of the Description panel. If necessary, you must specify the number of stations in your PDC/ATC storage system.
(For information on the other fields in this window, see Description Panel.)
