Keep Tooling
Keep Tooling retains the previous tooling on a part if you rotate it or add patterns in PART View. If you do not enable Keep Tooling, all of the tools are lost if you rotate the part after assigning tools. This option is found on the Main Menu>Toggle Toolbar.
See Retaining Tooling when Rotating Parts for more information.
