Dodge Clamps
This option instructs the system to avoid the clamps while sequencing. The cutting head or punching head remains a specified distance away from the clamps according to the user-entered value.
Notes -
This option is a temporary (for the current session) toggle, and will not switch the Dodge Clamps options ON or OFF in the Sequence Information Panel. However, values entered and saved in the Sequence Info Panel will be used as the default avoidance distance.
This toggle functions for any currently loaded driver; that is, if a cutting, combo or punching machine is loaded, this option will still toggle the function ON/OFF.
Find the default setting and value for Dodge Clamps in the Machine Setting>Sequence Info Panel.
