Cut Corner Feature Options
The Add Corner Features option on the Sequence Features tab allows the user to apply exact stop, radius, loop and tab features to the corners of a part.
Add Corner Features
To place features on part corners, select Add Corner Feature from the Cut Features submenu. When the Corner Features flyout window appears, move into the window and select the desired feature type from the Corner Value drop-down menu. You have the choice of None, Exact Stop, Radius Corner, Loop Corner or Tab Corner.
You must define the size for a Radius Corner, Loop Corner or Tab Corner by typing a value into the Corner Value field. When you have selected the corner feature type and defined its size, move into the work area and click the corner (intersection) where you want to place the corner feature.
Edit Corner Features
To modify the corner features, select Edit Corner Feature from the Cut Features submenu. The Corner Features window appears. When you move into the work area, the pointer snaps between the corner features. Click the corner feature to select it and then modify its properties using the options in the Corner Features window.
Corner Features Window
Whenever you add or edit corner features, the Corner Features flyout window appears. The window contains options that allow you to add, edit or delete corner features. You can modify the corner type and the approach and depart conditions.
Note: Once Corner Features are applied, the Edit Corner Feature icon becomes enabled. Click on it to change the Operation Type to Edit.
Operation Type
There are three options you can select from the drop-down list: Add, Edit and Delete.
Add
The Add option will appear by default when the system is in Add Corner Features mode. Select Add if you want to add corner features, rather than edit or delete corner features. The system remains in Add Corner Features mode until you select another option.
Edit
The Edit option will appear by default when the system is in Edit Corner Feature mode. Select Edit if you want to modify the corner features. The system remains in Edit Corner Feature mode until you select another option.
Delete
Select Delete if you want to remove corner features. You can then move into the work area and select those corner features that you want to remove. The system remains in Delete Corner Features mode until you select another option.
Corner
The options in the Corner section of the window allow you to select the feature type and specify a corner value.
Corner Type
You can select one of five corner types from the drop-down list: None, Exact Stop, Radius Corner, Loop Corner or Tab Corner.
Corner Value
Type a value in this field to define the size for Radius, Loop or Tab corner features.
Conditions
The options in the Conditions section of the window allow you to define the Approach Node and Depart Node conditions for a corner feature.
Approach Node
To define an Approach Node condition, move into the Corner Features window and select Enable from the Approach Node drop-down list.
Approach Value
Click the navigation button that appears next to the field to open the Cutting Conditions window. Select and define the cutting conditions of your choice and then click OK to close the Cutting Conditions window. Type a value in the Approach Value field to define the node distance. The node distance from radius or tab corners originates from the tab or radius end points and not the actual intersection or apex of the corners.
Depart Node
To define a Depart Node condition, move into the Corner Features window and select Enable from the Depart Node drop-down list.
Depart Value
Click the navigation button that appears next to the field to open the Cutting Conditions window. Select and define the cutting conditions of your choice and then click OK to close the Cutting Conditions window. Type a value in the Depart Value field to define the node distance. The node distance from radius or tab corners originates from the tab or radius end points and not the actual intersection or apex of the corners.
Note: Corner features may also be applied through the System Setting>Material>Corners panel.
