Pro/EngineerĀ® Integration
This section explains the process of importing Pro/Engineer files into the CAD/CAM System using OLE integration. The procedure is outlined below. The most important step is to convert the three-dimensional model to a flat layout within Pro/E before attempting the importation process. |
To transfer a Pro/Engineer part into the CAD/CAM System: |
1. Both the CAD/CAM System and Pro/E must be running. |
2. Switch to Pro/E. |
3. Load the sheet metal part into Pro/E. |
4. Make sure the Sheet Metal application module is active. Open the Application menu and make sure Sheet metal is selected. |
5. Select Feature in the Menu Manager. The menu will expand. |
6. Select Create to expand the menu. |
7. Select Unbend under SHEET METAL. |
8. Select Done under UNBEND OPT. |
9. Click the face of the reference flange. |
10. Select Unbend All in the Menu Manager and then click Done. |
11. Click OK in the (Regular Type) window. Pro/E will unfold the part. |
12. Switch to CAD/CAM. Click the OLE button in the Standard toolbar. The Pro/Engineer Importer window will appear. Wait for CAD/CAM to process the geometry. The Pro/E part will appear in the work area. You can then save the part in the CAD/CAM System. |
