MJC and IJP Manual
What is MJC and IJP Unloading?
MJC (Micro Joint Cutter) is a device that cuts the bridge microjoints that hold the part in the unloaded sheet. IJP (Ink Jet Printer) is a device capable of printing information on the parts. There are two configurations; the two devices may be combined or separate devices.
The option MJC/IJP is found in the Modules menu. There are three options: MJC Sequence, IJP Text and MJC/IJP Setting. |
MJC Sequence |
Defines the sequence the machine will use to cut the microjoints. |
IJP Text |
Print characters on the part(s) or sheet(s). |
MJC/IJP Setting |
Place the microjoint cut flags and the text on the sheet. |
Notes: |
1. |
A message will prompt you to select the MJC when selecting Apply in the Punching Microjoints menu (Machine\Edit Material). The system will generate the microjoints automatically according to the settings in the Punching Microjoints panel when selecting Yes. |
2. |
You can add the microjoints cut by the MJC machine manually using the Place Microjoint option (Sequence Features/Punch Microjoint). |
3. |
The machine driver must support the MJC function, or the MJC section in the Microjoint properties window will be absent. |
Select the MJC/IJP Setting option from the MJC/IJP submenu to access the MJC/IJP Setting window. The window is divided into two sections: MJC and IJP. The options in the MJC section allow you to set the Micro Joint Cutter settings, while those in the IJP section allow you to set the Ink Jet Printer settings.
MJC |
Micro Joint Cutter |
Work and Part |
Sheet Thickness |
Specifies the thickness range for MJC cutting. (Default Value: Min = 0.4, Max = 3.2.) |
Work Size X |
Specifies the work size for MJC cutting in the X direction. (Default Value: Min X = 900, Max X = 2500.) |
Work Size Y |
Specifies the work size for MJC cutting in the Y direction. (Default Value: Min Y = 900 and Max Y = 1250.) |
Min Part Size X |
Specifies the minimum part size for MJC cutting in the X direction. (Default Value: X = 120.) |
Min Part Size Y |
Specifies the minimum part size for MJC cutting in the Y direction. (Default Value: Y = 50.) |
Note: the part size is calculated according to the overall rectangular size. |
Cutter |
Corner Joint |
Specifies the offset value of the MJC cutting coordinate. The range can be set from 0.0 to 9999.9999. The offset value is added according to the coordinate. If the cutter rotates, the coordinate axis will also rotate (Default Value: X = 0.0, Y = 0.0.) |
Bridge Joint |
This is the same as a microjoint. (Default Value: X= 0.0 Y= 0.0.) |
Special Tool Joint |
Cutter Size X |
Specifies the horizontal cutter size. The cutter is inserted into the hole that has been punched out. Defines the hole for the MJC cutting coordinate in the X direction. (Default value: X = 30.0.) |
Cutter Size Y |
Specifies the vertical cutter size. The cutter is inserted into the hole that has been punched out. Defines the hole for the MJC cutting coordinate in the Y direction. (Default value: Y = 5.0.) |
Device Type |
This is the device type: No Vacuum/Vacuum. (Default Value: X = 0.0 Y = 0.0.) |
IJP |
Ink Jet Printer |
No |
This is the flow number. |
Brand |
The manufacturer of the IJP device. H = Hitachi, U = Union. |
Font Size |
The size of the font. |
Max String Number |
Specifies the maximum number of characters that can printed. |
Line Feed Character |
Specifies the line-feed code used in printing several character strings. |
Max String of Lines |
Specifies the maximum number of lines that can be printed. |
String Pitch |
Specifies the pitch for the character strings. |
Raster Size ID |
Character size information that is sent to the IJP. The printer will use the raster size and string size information to determine the actual character size and pitch when printing. (This is used to draw the interference. Check with the hole during simulation. The actual character size is determined by this information.) |
String Size ID |
This is the character size ID that is sent to the IJP. |
OK |
Applies the settings to the current session. |
Cancel |
Exits without saving the changes. |
You must define the MJC sequence after specifying the parameters. Select MJC Sequence from the MJC/IJP submenu. The options in this window allow you to define the parameters for the micro-joint cutting. |
Sheet Sequence |
Define the sheet sequence for microjoint cutting. |
Start Corner + Direction |
The radio buttons represent the actual starting corner: Upper Left, Upper Right, Lower Left or Lower Right. The button in the center functions as a toggle, allowing you to specify the direction. |
Number to Divide |
Set numbers of divided sections. |
Cut Count |
Indicates the number of microjoints to be cut. |
View Sequence |
Select to view the sequence. |
MJC Sequence |
Specifies the part processing sequence. |
Cut Sequence |
The cut sequence of the microjoint on the sheet. |
Cut Position |
The actual coordinates of the microjoint. |
Tool # |
The station number containing the cutter tool. |
Cut Type |
The type of cut. |
OK |
Cancel |
Exits without saving any changes. |
Defining the text printed on the part(s) involves selecting the field codes used to print specific information on them. For example, if selecting the field code that represents the Part File Name, the system will print the name of the actual CAD file on the part. |
Select IJP Text from the MJC/IJP submenu in order to define the text. The IJP Setting window will appear. The options in this window allow you to select which information you want printed on the part(s). |
IJP Setting |
No |
Select a machine number (No) from the drop-down list: 1-3. |
Auto |
The system automatically places the text according to your selection from the drop-down list: Top Right, Top Left, Bottom Right or Bottom Left. |
Fix Position |
Specifies the exact position by typing coordinates in the Position X and Position Y text boxes. |
Position X |
This option only becomes available if you select Fix Position. (This is the IJP position in X direction.) |
Position Y |
This option only becomes available if you select Fix Position. (This is the IJP position in Y direction.) |
Alignment |
Left, Center and Right alignment buttons allow you to specify the origin output for the text. |
Left |
The text will be placed with the origin output relative to the left. |
Center |
The text will be placed with the origin output relative to the center. |
Right |
The text will be placed with the origin output relative to the right. |
Enter Text |
The two lists in this section allow you to select the text that will be placed on the part(s). |
Text List |
Double-click an item in the list to add content to the Text Box on the right. |
Text Box |
Type the text that you want to print on the part(s). |
Restore |
Recall any text previously typed in the Text Box. |
Place |
Place the text on the part automatically according to the Auto or Fix Position settings. |
OK |
Delete |
Removes the text from the part. |
Cancel |
Exits without placing the text on the part. |
1. |
You must perform all the options while Part mode (Part View) is active. |
2. |
The tool guide appears in the work area when you place the text on the part. |
3. |
The settings will be saved after you end the session. |
4. |
The Text Box in the Enter Text section supports multiple lines. |
