Menus
The menu bar along the top of the program window contains a set of menu items. If you select a menu item, a list of associated command options appears. Use the mouse to navigate the menus by pointing to select the desired option.
| File Menu | ![]()  |
			Layout Menu |
| Edit Menu | View Menu | |
| Draw Menu | Help Menu | |
| Insert Menu |
The File menu consists of six options: New, Open…, Save, Save As…, Page Setup… and Exit.
New
Select New from the File menu, or press <Control> + <N> to create a new report template file. See Creating a New Report.
Open
Select Open… from the File menu, or press <Control> + <O> to open an existing report template file. See Opening an Existing Report.
Save
Select Save from the File menu, or press <Control> + <S> to save a report template under its current file name. See Saving a Report
Save As
Select Save As… from the File menu to save the currently open report under a new file name. See Saving a Report.
Page Setup
The Page Setup… option on the File menu allows you to specify the overall layout for the report. You can choose the paper size and set the margins in the Print Setup dialog box.
Option  |
			Description  |
Paper Size  |
			Click the Paper Size arrow button to select the paper size you normally use for printing reports.  |
Width  |
			This is a static field. It displays the paper width.  |
Height  |
			This is a static field. It displays the paper height.  |
Margins  |
			Type values in each of the text boxes to specify the sizes of the margins.  |
Left  |
			Type a value for the width of the left margin.  |
Right  |
			Type a value for the width of the right margin.  |
Top  |
			Type a value for the height of the top margin.  |
Bottom  |
			Type a value for the height of the bottom margin.  |
Exit
Select Exit from the File menu to quit the program. The system will prompt you to save the current report.
The Edit menu consists of six options: Cut, Copy, Paste, Select All, Delete and Font.
Cut
This option will cut a selected object from the work area and place it on the clipboard. To use this option, move the mouse point over the object you want to cut and click it until the selection handles appear. Select Cut from the Edit menu or press <Control> + <X>. The selected object will disappear from the work area.
Copy
This option will copy a selected object from the work area and place it on the clipboard. To use this option, move the mouse pointer over the object you want to copy and click it until the selection handles appear. Select Copy from the Edit menu or press <Control> + <C>. The original object will remain visible in the work area.
Paste
This option will paste an object that was cut or copied to the clipboard and restore it to the work area. The cut or copied object will appear each time that you use the Paste command.
Select All
The Select All option on the Edit menu will select all the objects you have placed in the work area. Selection handles will appear on all the objects to indicate the global selection.
Delete
The Delete option on the Edit menu will erase a selected object. To use this option, move the mouse pointer over the object you want to delete and click it until the selection handles appear. Select Delete from the Edit menu or press the <Delete> key. The object will be deleted from the work area.Note: Any currently selected object or objects in the work area are immediately deleted when you use this command.
Font
The Font option on the Edit menu will open the standard Font dialog box. You can select a default font, font style and size for the text and data field objects you place in the report.
The Draw menu consists of ten options: Line, Rectangle, Text, Data, Bmp Control, Table, Picture, Bring to Front, Send to Back and Redraw.
Line
			The Line option on the Draw menu allows you to create a line object. See Line Properties.  |
			Drawing a Line  |
			To draw a line, select Line from the Draw menu and move into the work area. Place the crosshair at the point where you want to start the line. Click and hold the left mouse button and then drag in any direction to draw the line. Release the mouse button when you reach the end point location for the line.  |
			Selecting a Line  |
			To select a line, move the pointer onto the line and click it. Selection handles appear at each end of the line.  |
			Moving a Line  |
			To move a line, move the pointer over the line until it becomes move pointer. Click and hold the left mouse button. As you start to drag, an outline of the object follows the pointer. Drag the line to the desired location and then release the left mouse button.  |
			Sizing a Line  |
			To resize a line, click the line until the selection handles appear. Move the pointer over a selection handle until it becomes a resize pointer. Click and hold the left mouse button and drag the end of the line you want to increase or decrease in size.  |
Deleting a Line
To delete a line, click the line until the selection handles appear. Click the Delete button or press the <Delete> key.
Line Properties
You can modify the style, thickness or color of a line. Double-click the line, or click the line until the selection handles appear and then press <Enter>. Make the desired selections from the Line Style, Thickness and Color drop-down lists and click OK in the Line Properties window to apply the changes.
Rectangle
			The Rectangle option on the Draw menu allows you to create square and rectangle objects. See Rectangle Properties.  |
			Drawing a Rectangle  |
			To draw a rectangle, select Rectangle from the Draw menu and move into the work area. Place the crosshair at the point where you want to start the corner of the box. Click and hold the left mouse button and then drag diagonally in any direction to draw the square or rectangle. Release the mouse button when you reach the opposite corner location for the square or rectangle.  |
			Selecting a Rectangle  |
			To select a rectangle or square, move the pointer inside the rectangle or square and click the left mouse button. Selection handles appear at each corner and at the midpoint of each line of the square or rectangle.  |
			Moving a Rectangle  |
			To move a rectangle, move the pointer over the square or rectangle until it becomes a move pointer. Click and hold the left mouse button. As you start to drag, an outline of the object follows the pointer. Drag the square or rectangle to the desired location and then release the left mouse button.  |
			Sizing a Rectangle  |
			To resize a rectangle or square, move the pointer over a selection handle until it becomes a resize pointer. Click and hold the left mouse button and drag the corner or side until the object increases or decreases to the desired size.  |
			Deleting a Rectangle  |
			To delete a square or rectangle, click the object until the selection handles appear. Click the delete button or press the <Delete> key.  |
You can modify the fill, color, style, line thickness and color of a square or rectangle. Double-click the object, or click the object until the selection handles appear and then press <Enter>. Make the desired selections in the Rectangle Properties window and then click OK to apply the changes.
Text
			The Text option on the Draw menu allows you to create a label or text object. See Text Properties.  |
			Drawing a Text Object  |
			To draw a text object, select Text from the Draw menu and move into the work area. Place the crosshair at the point where you want to start the corner of the text box. Click and hold the left mouse button and then drag diagonally in any direction to draw the text box. Release the mouse button when you reach the opposite corner location for the text box.  |
			Selecting a Text Object  |
			To select a text object, move the pointer move the pointer inside the label box and click the left mouse button. Selection handles appear at each corner and at the midpoint of each line of the text box.  |
			Moving a Text Object  |
			To move a label, move the pointer over the text box until it becomes a move pointer. Click and hold the left mouse button. As you start to drag, an outline of the object follows the pointer. Drag the text box to the desired location and then release the left mouse button.  |
			Sizing a Text Object  |
			To resize a label, click the label until the selection handles appear. Move the pointer over a selection handle until it becomes a resize pointer. Click and hold the left mouse button and drag the corner or side until the object increases or decreases to the desired size.  |
			Deleting a Text Object  |
			To delete a text object or label, click the object until the selection handles appear. Click the Delete button or press the <Delete> key.  |
Text Properties
You can modify the fill, line and comment properties for a text object or label using the options in the Text Label Properties window. Double-click the object, or click the object until the selection handles appear and then press <Enter> to display the window. Make the desired selections in the Text Label Properties window and then click OK to apply the changes.
Data
			The Data option on the Draw menu allows you to create a data control or field object. See Data Control Properties and Understanding Data Variables.  |
			Drawing a Data Control  |
			To draw a data object, select Data from the Draw menu and move into the work area. Place the crosshair at the point where you want to start the corner of the data box. Click and hold the left mouse button and then drag diagonally in any direction to draw the data box. Release the mouse button when you reach the opposite corner location for the data box.  |
			Selecting a Data Control  |
			To select a data object, move the pointer inside the data box and click the left mouse button. Selection handles appear at each corner and at the midpoint of each line of the data box.  |
			Moving a Data Control  |
			To move a data object, move the pointer over the data box until it becomes a move pointer. Click and hold the left mouse button. As you start to drag, an outline of the object follows the pointer. Drag the data box to the desired location and then release the left mouse button.  |
			Sizing a Data Control  |
			To resize a data control object, click the object until the selection handles appear. Move the pointer over a selection handle until it becomes a resize pointer. Click and hold the left mouse button and drag the corner or side until the object increases or decreases to the desired size.  |
			Deleting a Data Control  |
			To delete a data object, click the object until the selection handles appear. Click the Delete button or press the <Delete> key.  |
			You can modify the fill, line and comment properties for a data or field object using the options in the Data Control Properties window. In addition, you can select a variable to display the information contained in a specific database field. See Understanding Data Variables  |
			Double-click the object, or click the object until the selection handles appear and then press <Enter> to display the window. Make the desired selections in the Data Control Properties window and then click OK to apply the changes.  |
Bmp Control
			The Bmp Control option on the Draw menu allows you to insert a bitmap or *.bmp files into the report. You can use this feature to add a logo to your report.  |
			Drawing a Bmp Control  |
			To place a bitmap, select Bmp Control on the Draw menu and move into the work area. Place the crosshair at the point where you want to start the corner of the Bmp box. Click and hold the left mouse button and then drag diagonally in any direction to draw the Bmp box. Release the mouse button when you reach the opposite corner location for the Bmp box.  |
			The Open dialog box will appear and list the *.bmp files that are stored in the default \TemplateReport folder. If necessary, navigate to the desired folder that contains the *.bmp file you want to insert. Click the file to select it and then click Open. The bitmap object appears within the Bmp box.  |
			Selecting a Bmp Control  |
			To select a Bmp object, move the pointer inside the Bmp box and click the left mouse button. Selection handles appear at each corner and at the midpoint of each line of the Bmp box.  |
			Moving a Bmp Control  |
			To move a Bmp object, move the pointer over the Bmp box until it becomes a move pointer. Click and hold the left mouse button. An outline of the object follows the pointer as you begin to drag. Drag the Bmp box to the desired location and then release the left mouse button.  |
			Sizing a Bmp Control  |
			To resize a Bmp control object, click the object until the selection handles appear. Move the pointer over the selection handle until it becomes a resize pointer. Click and hold the left mouse button and drag the corner or side until the object increases or decreases to the desired size.  |
			Deleting a Bmp Control  |
			To delete a Bmp object, click the object until the selection handles appear. Click the Delete button or press the <Delete> key.  |
Table
			You can insert a table into a report to present data in a columnar format. There are two types of tables: a Bending Report Table and a Turret Tool List Table. The data in the Bending Report Table corresponds to the bend properties you have defined for all the construction or bend lines in a part. The data in the Turret Tool List Table corresponds to all the station information you have defined in the turret setup. See Table Properties.  |
			Drawing a Table  |
			To draw a table, select Table from the Draw menu and move into the work area. Place the crosshair at the point where you want to start the corner of the table. Click and hold the left mouse button and then drag diagonally in any direction to draw the table. Release the mouse button when you reach the opposite corner location for the table.  |
			Selecting a Table  |
			To select a table object, move the pointer inside the table box and click the left mouse button. Selection handles appear at each corner and at the midpoint of each line of the table box.  |
			Moving a Table  |
			To move a table object, move the pointer over the table box until it becomes a move pointer. Click and hold the left mouse button. An outline of the object follows the pointer as you begin to drag. Drag the table box to the desired location and then release the left mouse button.  |
			Sizing a Table  |
			You should modify the table properties before you attempt to resize it. You will want to choose a table format and the data columns you want to include in the columnar layout. See Table Properties.  |
			To resize a table, click the object until the selection handles appear. Move the pointer over the desired selection handle until it becomes a resize pointer. Click and hold the left mouse button and drag the corner or side until the object increases or decreases to the desired size.  |
			Deleting a Table  |
			To delete a table object, click the object until the selection handles appear. Click the Delete button or press the <Delete> key.  |
Table Properties
The system will insert a default table into the report when you have finished drawing it. The table will lack any labels along the top row. You must therefore select the table type (format) and the columns that you want to print. You can select the table and press <Enter> or double-click the object to display the Table Properties window. See Bending Table and Turret Tool List Table.
			To choose the actual format or type, select either Bending Table or Turret Tool List Table from the drop-down list:  |
Bending Table
			If you select Bending Table, the Column to Print window will list the data fields that correspond to the bend properties you have defined for all the construction or bend lines in a part:  |
			Place a check mark in the appropriate check box to display a particular column of information. If you remove the check mark, the column will be omitted from the table. When you click OK, table will update and the column names you selected in the window will appear in the first row:  |
			If you select Turret Tool List Table, the Column to Print window will list the data fields that correspond to all the station information you have defined in the turret setup:  |
			A picture object will display a graphical representation of the part, sheet or turret. For parts with bend properties assigned to the construction or bend lines, the picture object will display a three-dimensional image of the completed bend process. See Picture Properties.  |
			Drawing a Picture Object  |
			To draw a picture object, select Picture from the Draw menu and move into the work area. Please the crosshair at the point where you want to start the corner of the picture box. Click and hold the left mouse button and then drag diagonally in any direction to draw the picture box. Release the mouse button when you reach the opposite corner location for the picture box.  |
			Selecting a Picture Object  |
			To select a picture object, move the pointer inside the picture box and click the left mouse button. Selection handles appear at each corner and at the midpoint of each line of the picture box.  |
			Moving a Picture Object  |
			To move a picture object, move the pointer over the picture box until it becomes a move pointer. Click and hold the left mouse button. An outline of the object follows the pointer as you start to drag. Drag the picture box to the desired location and then release the left mouse button.  |
			Sizing a Picture Object  |
			To resize a picture object, click the object until the selection handles appear. Move the pointer over a selection handle until becomes a resize pointer. Click and hold the left mouse button and drag the corner or side until the object increases or decreases to the desired size.  |
			Deleting a Picture Object  |
			To delete a picture object, click the object until the selection handles appear. Click the Delete button or press the <Delete> key.  |
Picture Properties
			The system will insert a default part picture into the report when you have finished drawing it. You must therefore select the picture type that you want to print. You can select the picture object and press <Enter> or double-click the object to display the Picture Properties window  |
			Click the Picture Type: arrow button and select the desired option from the drop-down list. Click OK to update the picture object.  |
Bring to Front
			The Bring to Front option will shift a selected object to the foreground. The object will overlap any other objects relative to it. In the example below, the Bring to Front option was used on the center rectangle. The center rectangle now overlaps the left and right rectangles.  |
Send to Back
			The Send to Back option will shift a selected object to the background. The object will be overlapped by any other objects relative to it. In the example below, the Send to Back option was used on the center rectangle. The left and right rectangles now overlap the center rectangle.  |
Redraw
The Redraw option will refresh the view in the work area.
			The Insert menu has two options: Page Header and Page Footer. A page header or footer can consist of page numbering, date stamps and custom comments that clarify the contents of the report.  |
Page Header
			Select Page Header from the Insert menu to define the elements for the report header. See Header and Footer Options.  |
Page Footer
			Select Page Footer from the Insert menu to define the elements for the page footer. See Header and Footer Options.  |
			The Page Header and Page Footer windows share the same options. The only difference is whether the elements are placed in the header or footer section of the document.  |
			The Left, Top, Right and Bottom options on the Layout menu determine the alignment of selected objects relative to each other.  |
Left
			The Left option on the Layout menu allows you to align the left edges of all the selected objects. In the example below, the two rectangle objects shift left relative to the left edge of the left-most rectangle.  |
Top
			The Top option on the Layout menu allows you to align the top edges of all the selected objects to the top edge of the top-most object. In the example below, the two rectangle objects shift upwards relative to the top edge of the top-most rectangle.  |
Right
			The Right option on the Layout menu allows you to align the right edges of all the selected objects. In the example below, the two rectangle objects shift right relative to the right edge of the right-most rectangle.  |
Bottom
			The Bottom option on the Layout menu allows you to align the bottom edges of all the selected objects to the bottom edge of the bottom-most object. In the example below, the two rectangle objects shift downwards relative to the bottom edge of the bottom-most rectangle.  |
			The options on the View menu function as toggles. If an option has a check mark, that element of the interface will appear. If you remove the check mark, the interface element is hidden from view. The Status Bar option on the View menu functions as a toggle. A check mark next to the option will display the status bar along the bottom of the application window. If you remove the check mark, the status bar is hidden from view. The Grid Line option on the View menu functions as a toggle. A check mark next to the option will display the grid lines in the work area. If you remove the check mark, the grid lines are hidden from view. The options on the Toolbars submenu function as toggles. A check mark next to an option will display that element of the interface. If you remove the check mark, the element is hidden.  |
Help Menu
			Select Manual Help, Help F1 to open the manual or About to display the copyright and version information.  |
