Selecting Parts on the Sheet
Use this option to select a part on a sheet that has multiple parts. When a part has been selected it becomes active and the part boundaries change to a pink color. Select Part View to edit the part separately. To arrange/rotate parts on a sheet, the CADCAM program must be in Sheet View.
To quickly toggle between Part and Sheet views, just hit <F5> on the keyboard.
 After loading multiple parts onto a sheet, the parts may be stacked in the bottom left corner, which is the default origin or 0X, 0Y reference point.
