Reset Unloading Sequence
This option deletes the entire unloading sequence. Select Reset from the submenu. The system will prompt for confirmation: "Do you really want to reset TK/PRII unloading sequence <Y> or <N>?" If you press <Y>, the unloading sequence of the parts on the sheet will be deleted. Press <N> to cancel the operation.
Selecting this option will also delete any custom configuration the user has set for the part remover arms.
