The Reset Sequence option clears any previous punch sequence. To erase the sequence, select Reset Sequence and the system will open a confirmation dialog. Click Yes to reset the sequence or No to cancel. When the sequence is reset, the system redraws the sheet with the non-sequenced parts.
Note: For combination machines, this option clears the punch and cut sequence.
