Reposition Sheet
This option allows the user to shift the position of the sheet.
Select Reposition from the submenu, and the system will prompt you to move into the workspace and set a reposition location. Move the cursor into the work area. The system will prompt you to enter the location of the reposition line. Type the coordinates using the keyboard or use the cursor to determine the position. As you move the cursor, the sheet will move along the horizontal axis. Click the left mouse button to accept the location.
Note: This option is only used with combo machines, or lasers (such as the Amada Pulsar) that use moving clamps.
