PRII / PRIII Settings
Whether you select Info from the PRII or PRIII Unloading submenu, the Information Setup window will appear. The options in the window allow you to specify the settings for the arms and storage table that compose the unloading device.
1.   When you select an arm, it will turn red in the preview area.
2.   When you select a cup, it will turn red in the preview area.
3.   Click the cells in the Arm Information table and make modifications to individual suction cups.
4. The options that appear in this window depend upon the driver/machine loaded.
A PRII window may have fewer options
Preview Area / Storage Table
The arm layout and suction cup layout will appear in the Preview area.
Length / Height
Enter the length and height of the storage table.
Location X / Y
Enter the location of the table.
Layout
Two different layout methods (Sheet/Stack) for auto unloading are supported. Sheet will place the parts as they appeared on the original sheet. Stack will stack the same parts (with the same rotation) one on top of the other within Max Storage Height limits.
Arm Distance
The settings in this section define the minimum and maximum distances between the arms.
Note: The Simulator supports part removal arms up to and longer that 70 inches.
Min Distance
The allowable minimum distance between the two arms.
Max Distance
The allowable maximum distance between the two arms.
Default Distance
The default distance between the two arms.
Offset Limit
The fields in the Offset Limit section display information for the offset from the punch head at the three track locations (or the laser head) as measured in the X and Y directions to the left bottom of the first arm.
Cutting Divided Offset(M383)
M383 will leave the last line uncut until the part remover arms come and stabilize the part, and then the last cut will occur.
Note: The Cutting is Divided check box must be enabled for this option to work.
   Offset  X-Direction
The offset from the turret station in the X direction.
   Offset Y-Direction
The offset from the turret station in the Y direction.
Not Divided Offset(M384)
This option will cut out the last line first and then the part remover will comes to remove the part.
Note: Cutting is Divided must be unchecked.
   Offset X-Direction
   Offset Y-Direction
   Punch X-Direction
The distance from the tool to the part remover arms in the X direction.
   Punch Y-Direction
The distance from the tool to the part remover arms in the Y direction.
Over Travel
Specify the vertical maximum over travel for the arms to ensure the arms are within the specified Y traveling range.
Over Travel X
Set the value for overtravel in X.
Over Travel Y
Set the value for overtravel in Y.
Note: If the Y value of the parts exceed the “Over Travel Y” value, AP100US will always set “arm2 (or B arm)” as the based arm.
Auto Detect
If you place a check mark in the Auto Detect check box, the system will detect the cup status (On/Off) automatically when you edit the arm.
Cutting is Divided
If the X coordinate of the last cut does not have any movement and this option is enabled, the outer loop of the part will be divided. If you remove the check mark, the outer loop will not be divided.
Rotate Unloader
Check this box to allow the arms of the TK Unloader to rotate.
Note: This is a driver-dependent option, and will not function with all drivers.
Last Hit Speed
If the machine speed is too fast, a loose part may crash the turret. Use the Last Hit Moved Speed function to control the machine speed to avoid this problem.
Select one of the four speed values - F1 is the fastest speed while F3 is the lowest. The system will output the selected last hit tool moved speed in the NC code.
Unloader Speed
Select the unloading speed from the drop-down list.
Rotate Unloader
Rotate Unloader is not available in PR.
Unload Order
Allows the user to select the unload order. The image shows the order starting in the upper left corner and moving in the Vertical order.
Extra Z-movement
This box is checked on by default to allow extra movement in Z.
Uncheck the box to not allow extra movement in Z.
Shift Distance
To prevent the PR from colliding with the turret when it removes parts, the system shifts the sheet before PR picks up parts. Specify the shifting distance here.
Extra Z-movement
Check this box to allow extra Z movement for the part remover arm to prevent the Part Remover arms from colliding with the laser head.
Shift Speed
To prevent the PR from colliding with the turret when it removes parts, the system shifts the sheet before PR picks up parts. Specify the Shift Speed here (F1 being the fastest and F4 being the slowest).
Arm Information
This section is used to specify the parameters for each arm and suction cups.
Arm ID
The ID number of the current arm
Arm Length
The length of the current arm.
Arm Width
The width of the current arm.
Cup Count
The number of suction cups on the current arm.
Suction Cup Table
This section is used to specify the parameters for each suction cup on the arm. When you click a specific cell in the table, the associated suction cup in the Preview Area turns red.
ID
The ID number of the cup.
Loc. X
The X coordinate of the cup.
Loc. Y
The Y coordinate of the cup.
Sensor Cup
Sensor Cup allows the user to define which cup (or cups) functions as a sensor cup.
Note: At least one sensor (or sensor group) must be over a part to pick up.
Radius
The radius of the cup.
Link
The link or row number of the cup.
Plc Code
The code defined for a cup that is recognized by the system.
Model
The model of the cup. 1 is for vacuum, 2 is for magnet.
Group
The group number of the cup.
Import
Use this option to open an unloader file in the *.xml format.
Export
Use this option to save an unloader file in the *.xml format.
OK
Click OK to save the changes and to close the window.
Cancel
Click Cancel to exit without saving any changes.
