Gripper Unloading Manual
What is Gripper Unloading?
The Gripper Unloading module is an optional software package that enhances the functionality of the CADCAM System. The features in Gripper Unloader were designed to support machines like the Behrens CB2011 .
Quick Start Guide
The Quick Start Guide summarizes the gripper unloading process. Review this outline of the Gripper Unloading features. For commands or tasks you do not fully understand, reference the appropriate section.
Start Gripper Unloading
To prepare for Gripper Unloading, launch the CAD/CAM System. Select Sheet from the View menu. Sheet view must be active before you can use any of the options on the Gripper Unloading submenu.
Load the Machine File
Select Open from the File menu, or click the Open File button in the Standard toolbar. When the Open File dialog box appears, select Machines (*.mac) from the Files of type: drop-down list. The system lists the machine files stored in the \Turrets directory by default. If necessary, use the Look in: drop-down list to navigate the hierarchical folder structure. Scroll through the file list window and click the name of the machine file. Click Open to load the machine file. If necessary, edit or load a material file. Click Close to exit the Open File dialog box.
Load the Machine Driver
Select Info from the Machine menu to open the Machine Setup window. Click the Driver File button. The Open dialog box displays the machine drivers stored in the \Machine directory by default. If necessary, use the Look in: drop-
down list to navigate the hierarchical folder structure. Scroll through the file list window and click the name of the driver file. If necessary, edit or load a material file. Close the Machine Setup window.
Specify the Gripper Information
Open the Modules menu. Select Info from the Gripper Unloading submenu to open the Unloading Gripper dialog box. Specify the Tab Tool Information, Gripper Clamps, Unloading Area and Unloading Direction by either typing the values in the text boxes or by selecting the appropriate option buttons. Click OK to save the gripper unloading information.
Create the Gripper Sheet
Load the parts onto the sheet and grid them if necessary. Use the Assign Tab for Gripper or the Assign Tab for Chute options on the Gripper Unloading submenu to place unloading tabs on the parts. You can also use the respective buttons on the Gripper toolbar to place tabs on the parts.
Sequence the Gripper Functions
Use the
Reset,
Auto,
Manual,
Undo,
View and
Reposition options
submenu to remove the parts from the
sheet.
Save the Gripper Sheet |
Select
Save As from
the File menu,
or click the Save As button in the Standard toolbar to open the
Save As dialog box. Select Sheets
(*.sht) from the Save as type: |
Preparation
You must complete several steps before you can create a sheet having gripper-unloading functions:
If necessary, activate Sheet view.
Define the sheet size and thickness.
Load the parts on the sheet.
Select and arrange the parts on the sheet.
Please reference Chapter 5: Sheet Layout in the CAD/CAM System manual for more details. Once you have completed the part layout, you can define the gripper-unloading functions for the sheet. The remainder of the process involves loading a machine file and gripper driver, and specifying the gripper information, assigning tabs for the gripper or chute, and sequencing the sheet.
A
machine file contains the physical parameters of a machine. You must load
the correct machine file before you can define a sheet having gripper
functions. Machine files have the filename extension of *.mac, and are
To load the machine file:
Select Open from the File menu, or click the Open File button in the Standard toolbar. The Open File dialog box appears.
Click the Files of type: arrow and select Machines (*.mac) from the drop-down list.
If necessary, use the Look in: list to navigate the hierarchical folder structure.
Scroll through the file list window and click the name of the machine file you want to load.
The next step involves checking the machine driver, and if necessary, selecting the correct driver that supports gripper-unloading functions. Your machine driver must support gripper functions before you can use them. Please contact your CAD/CAM System representative for more information on custom drivers.
Unloading Gripper Window
You must specify the gripper information before you can use any of the gripper functions. If this information already exists in the machine file, then you only need to examine the values to ensure they are correct. If necessary, you can view and edit the values using the Unloading Gripper window.
To display the Unloading Gripper window:
Make sure Sheet view is active. If necessary, select Sheet from the View menu.
Open the Modules menu, and highlight (select) Gripper Unloading to open its
submenu.
Select Info from the Gripper Unloading submenu. When the Unloading Gripper window opens, the contents of the Location 1 text box in the Tab Tool Information section are selected by default.
Type the values in the various text boxes. You can navigate the text box fields within the window using a combination of the <Tab> and <Shift> keys. Press <Tab> to move to the next field, or <Shift> + <Tab> to select the contents of the previous field.
When the information appears correct, click the OK button to save the changes and to exit the Unloading Gripper window.
The Tab Tool Information options allow you to specify the values for the tab locations on the part as measured from the bottom left corner of the part. |
Tab Tool Information Options |
Location 1 This is the first tab measured from the bottom left corner of the part. Location 2 This is the second tab measured from the bottom left corner of the part. Width The X dimension of the microjoint depicting the tab on the part. Height The size of the slitting tool between parts. |
Gripper Clamps |
Note: You will use the Assign Tab for Gripper or Assign Tab for Chute options to assign tabs. |
The Gripper Clamp values specify the locations of the first and second clamps, as measured from the bottom left corner of the part. You may need to change this information according to the sheet layout and part sizes. |
Gripper Clamps Information Options |
Location 1 The first Y dimension measured from the bottom left of the part. Location 2 The second Y dimension measured from the bottom left of the part. Width The X dimension for the gripper clamps. |
Unloading
Area |
The Location X and
Location Y values
for the unloading area are derived from the machine's zero |
Unloading Direction
The Unloading Direction section allows you to specify the direction for the gripper.
Unloading Direction Options
X-Axis (Line by Line) This instructs the CAD/CAM System to move in the X-axis before moving in the Y- axis.
Y-Axis (Line by Line) This instructs the CAD/CAM System to move in the Y-axis before moving in the X- axis.
Creating a Sheet with Gripper Functions
Once you have loaded the correct machine file and gripper driver, and specified the correct values in the Unloading Gripper window, you can add the actual gripper functions to the sheet. This involves placing either gripper or chute tabs on the sheet. See Assign Tabs for the Gripper and Assign Tabs for the Chute.
Note: Make sure to check the gripper information before you begin. Use the Info option on the Gripper Unloading submenu to open the Unloading Gripper window.
For
parts large enough for the gripper, use the Assign
Tab for Gripper option on the
Gripper Unloading submenu,
or click the Assign Tool Tab for Gripper button in the Gripper toolbar.
The system prompts you to “Move into the work window and click on a part to assign tabs for the tab cutter.” Move the crosshair over each part or grid of parts you want to unload using the gripper. The gripper tabs appear when you click an individual part or a grid of parts.
If the message, “The part is too small to assign tool tab for gripper unloading” displays, try the Assign Tabs for the Chute option instead. The Tab Tool Information values in the Unloading Gripper window determine the size of parts that can be unloaded using the gripper.
If you click a grid, all parts belonging to that grid are assigned gripper tabs.
If the parts or grids of parts are too small for the gripper, you can try using the Assign Tab for Chute option on the Gripper Unloading submenu. You can also click the Assign Tool Tab for Chute button on the Gripper toolbar to activate the command.
The
system prompts you to “Select an arc or a line to place a bridge microjoint.”
Move the crosshair over a part or grid of parts you want to drop down
the chute. Move the crosshair over a part or a grid of parts and click
the left mouse button. A dashed outline that represents the chute and
two bridge microjoint indicators snap to the nearest line or arc.
The system now prompts you to “Select a bridge microjoint location.” Move
the mouse from left to right until the microjoint indicators are in the
correct position. Click the left mouse button to place the tabs.
Correcting the Sheet Setup
If while placing gripper or chute tabs produces unwanted results, you can choose to display the microjoints, and if necessary, remove them from the sheet.
View Tabs
To determine which parts have gripper tabs or chute tabs, select View Tabs from the Gripper Unloading submenu, or click the View Tool Tabs button on the Gripper toolbar. |
Delete |
To remove a tab for the gripper or chute, select Delete from the Gripper Unloading submenu, or click the Delete Tool Tab button on the Gripper toolbar. Move into the work area and click the part or grid of parts. The tabs are deleted from the sheet. |
Note: If you click a grid using the Delete option, all the tabs are removed from that grid on the sheet.
Sequence the Sheet
Sequence the sheet as you normally would using the options on the Punch Sequence menu, the Sequence Features menu, and the items listed in the Sequence Options window.
When you arrive at the point where you want to sequence with gripper features, see Sequencing Gripper Features.
The gripper options remove the parts from the sheet. The Auto, Manual, View and Reposition options sequence the gripper features. The Undo and Reset options allow you to correct errors in the gripper sequencing.
Auto
Use the Auto option on the Gripper Unloading submenu, or click the Auto Unload button on the Gripper toolbar, to automatically sequence the unloading of parts. The CAD/CAM System uses the gripper to remove the parts using the gripper tabs. For parts that have chute tabs, the system automatically drops them down the chute. If the parts marked for the chute do not fit within the chute's boundary, the system asks if the part should drop down the chute. Press <Y> for “Yes” or <N> for “No.” If the parts are out of range, you must reposition the sheet before you can use the Auto command. See Reposition. |
Manual |
Use the Manual option on the Gripper Unloading submenu, or click the Manually Unload Part button on the Gripper toolbar when you want to decide which parts to unload using the gripper or to drop down the chute. Select Manual from the Gripper Unloading submenu, and then move into the work area. Click each part you want to remove. If you click a part that does not fit within the chute's boundary, the system prompts you to confirm. Press <Y> for “Yes” or <N> for “No.” |
Undo
Use the Undo command on the Gripper Unloading submenu, or click the Undo Unloading button on the Gripper toolbar, to reverse the last gripper command you selected. You can then continue with your sequencing. |
Reset |
The Reset option on the Gripper Unloading submenu allows you to clear any previous gripper sequences. To clear the gripper sequence, select Reset from the Gripper Unloading submenu, or click the Reset Unloading button in the Gripper toolbar. The system prompts you to confirm the action. Press <Y> to reset the sequence or <N> to cancel. |
View |
To see the gripper
sequence, select View
from the Gripper
Unloading
submenu, or click the View Unloading
button in the Gripper toolbar. |
Reposition |
Repositioning allows you to use sheet sizes longer than your machine's maximum X travel. The repositioning function opens the clamps and moves them so you can complete the remainder of the sheet. You can also reposition in the reverse direction to return the clamps so the sheet does not hang off the edge of the table. To reposition the clamps during a gripper sequence, select Reposition from the Gripper Unloading submenu, or click the Reposition for Unloading button on the Gripper toolbar. The prompt instructs you to move into the work area and set the reposition location. As you move the pointer across the sheet, the reposition line appears and prompt asks you to choose its location. The location of the reposition line relative to the lower left corner of the sheet indicates the direction and distance you want the clamps to move.
Saving the Gripper Sheet
You should save your sheet frequently to prevent data loss during power outages or computer crashes. If you press the <F10> key while in Sheet view, the system saves your sheet under its assigned name in its default folder.
Note: If you have not yet named the sheet, pressing <F10> saves the sheet with the default name of NEW SHEET.
To save the sheet:
Make sure you are in Sheet view. To save the sheet under a new name, select Save As from the File menu, or click the Save As button in the Standard toolbar. The Save As dialog box appears.
If necessary, select Sheets (*.sht) from the Save as type: list. Type a name in the File name: text box. You need not add the filename extension; the system automatically adds the *.sht extension.
Click the Save button to save the sheet. Click the Close button to exit the Save As dialog box.
