Error Location Sparks
AP100US automatically checks the geometry for gaps any time you load or import a part. If the software detects a problem, it opens the file in PART View. As you exit any error messages, watch the part drawing. An Error Location Spark will appear in any vertex until the geometry forms a closed path. You can then take the necessary steps to examine and correct the geometry before processing the part.
