Use the Delete option to remove the unloading sequence from a specific part. Select Delete from the submenu. The system will prompt you to move into the work area and click a part. Move into the work area and the system will prompt you to click a part to remove the unloading part sequence. Click the desired part to remove the unloading sequence.
This action will remove the part selected from the unloading sequence, not removing it to the stacking table.
Click the option and then left-click a part on the sheet.
