Delete Macro
The Delete option allows the user to erase a macro. When the option is selected, the macro box and all the patterns defined as a macro appear in the default highlight color for easy identification. Select the option and click the macro. When this is done the macro and all associated patterns will be deleted.
Notes: Deleting a macro removes any tool assignments and sequencing.
If a macro pattern is deleted by accident, select the Undelete option to restore the macro pattern.
Undelete Macro
The Undelete option restores the last macro pattern that was deleted using the Delete command.
Notes: Only the last set of macro patterns can be restored, as the Delete command only erases the last set of macro patterns that was defined.
If a macro pattern is deleted from the sheet, use Undelete to restore it. The Undelete option also restores the tool assignments and sequencing.
