Delete Final Hit or Cut
This option is used to remove the final hit/final cut from the part. Select Delete Final Hit/Cut from the submenu. The system will prompt you to move into the work area and to click a part. Move the cursor into the work area. The system will prompt you to click a part to delete the final hit/cut. Click the desired part and the final hit/final cut is removed.
