The Check Dimensions
option allows the user to compare part dimensions against those on a blue
print. After dimensioning a part, select Check Dimensions
and begin selecting dimensions that correspond to those on a blueprint.
The dimension text and lines change color as a visual aid, signifying
that they have already been examined against the original drawing or specification.
